pendean
en respuesta a: tcorey
Surprise is the correct word, with all respect: re-read your post without knowing what you alone know and see what I mean.
So..
1) Is the problem simply that INSERT command is not finding the blocks you want?
2) Or you find the newer INSERT command just challenging to use?
3) Or is the block with that name already in use this one file with different content (or just a blank/empty block)? Try renaming the block in your file, then try INSERT again.
4) Or is the content of the block off-screen from where you are zoomed in (you need to zoom out), or the layers the content of the block are on are simply frozen/turned off?
If you are unsure, finish the insertion of your block, qsave, find it (SELECT command's LAST option should select it) then zoom out/in to reach it. Or post that DWG file here and tell us the name of the block and we can look for it.
HTH
