pendean
en respuesta a: Ntuthuko.
First time/day on a computer?
No one at your office or location know much about computers and backing up user files?
If I may ask:
How do you avoid losing all of your files when you change computers?
How do you avoid losing all your Word/Excel and photos files when you change software or upgrade there or change PCs?
You avoid it by backing up everything that is important to you: do you need help finding backup software?
Do you need help moving files to folder you control that you save to an external drive or cloud service?
In AutoCAD for example.... if you have one single template file that contains ALL of your blocks that you every need, then back up that file by simply opening your template file, using SAVEAS command, and locating it into one of your own folders outside of the AutoCAD program.
HTH
