sssteve72
en respuesta a: Alfred.NESWADBA
Well that at least is a possibility.  Though it is more complex than that.  Our profile is generated by our 3rd party software when it is installed ( I don't actually make one and it is not an "autocad" profile.  I've never really "migrated" at least not in the sense of using the old migration tool.  I didn't even copy my workspace over this time, I simply started a new one.
I do have a custom menu that I started new and then used the cui to transfer buttons and menus from the old one.  I eliminated a lot of old stuff when I did that.  But I believe I made that menu when I still had 2014.  That at least sounds testable.  I can unload my custom menu and leave it out for a few days and see if the problem goes away.  I assume it should be fine to use the cui to transfer toobar buttons from an older cui file?
Custom Build with Win7 Pro 64Bit SP1
Gigabyte Tecohnology Co. X79-UD3
3.60 gigahertz Intel Core i7-3820
16GB GSkill Ripjaw Z PC3 2133 PC17000
PCI-E ATI FirePro V7800 2GB 256bit
ATA SanDisk SDSSDX24 SCSI Disk Device (256 GB)
Dell 2001FP, 2407WFPHC, ASUSVN289 in Triple monitor setup
Question - Are you the Common Denominator?
