11-20-2015
09:27 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-20-2015
09:27 AM
If you and your colleague are accessing the same blocks from the same single source, you and them ought to have the same exact block UNLESS the block, defined wrongly, is already in the DWG file you are in.
IS there a reason you two are not accessing the same blocks from the same single source, centrally located on a share drive or server?
