539 Vistas, 2 Respuestas
Smart leader
Is it possible in Autocad 2021 if I have a multileader, and if I have a field in it, the field could automatically get out an objects property for example a length of a line, which the leader points to? I mean if the end of the leader touches a line for example, the field automatically get the length of it. And if I change the leader to point to a different object, the field would change automatically?
vinodkl
en respuesta a: Anonymous
Hi @Anonymous
sorry, there is no such feature in AutoCAD currently. You need to manually select the object to get its property as a field in the multileader :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
You may need to use an outsource lisp or plugin to get your need . I suggest to see if this one here is meet your needs .
Imad Habash
