dbroad
en respuesta a: claudediehl
I opened both drawings using AutoCAD 2019.  The first drawing posted had 11 errors and required recovery. There were also proxy objects.  I turned off the viewport to discover that all annotation was in the layout.  I checked display as plotted because yellow on white was giving me a headache.  I turned on the viewport and tried mirroring just about any annotative object. There was no problem selecting any f the resulting mirrored objects whether or not the original was deleted.  Could there be a memory issue at your end or a missing software update?  The drawings are relatively large for their content.  The purged version was half the size. The floor is oddly about 232' below the ucs world origin. I doubt any of that relates to your problem.  Do you have any third party customizations runing?
Just a thought.  If I'd left the objects at yellow, I doubt that I could tell that the objects were higlighted when selected.  Do you by any chance have your grip display off?
Architect, Registered NC, VA, SC, & GA.
