rickstarosto4361
661 Vistas, 4 Respuestas
can not save to save to 2021
IT department upgraded me autodesk products to 2021 from 2018, now when i try to SAVE AS, 2018 is the newest file type i can save as. what am i missing? HELP
qnologi
en respuesta a: rickstarosto4361
rickstarosto4361
en respuesta a: qnologi
i dug deeper and notices 2018 is default, i need to view forums more often. But here is another issue, when i am in my project in windows explorer and out of habit I select the .DWG file i want to view it tries to open the DWG in 2018 and i guess because i do not have 2018 in my PC i get this. i have to open through 2021. is that the norm now? cannot open files when in windows
pendean
Why would that be normal? Explore this from Autodesk https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/FLEXne...
You will need your IT to get involved I suspect.
HTH
rickstarosto4361
en respuesta a: pendean
i appreciate the help, going to forwared to IT and let them chew on this and hopefully in the next day or so they can figure it out :cara_con_una_leve_sonrisa: Again Thanks!!!
