02-05-2021
06:38 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-05-2021
06:38 AM
You're my hero. I started at a new company to run the drafting department and someone instead of setting up a standard across the board for how much the dimensions should offset from the line was having the team manually move them. I had a drawn with over 100 dimensions lines and was going through it one at a time pick the dimensions line, hovering over the #'s, selecting reset text position before going to the next one.
You just save me probably 20+ minutes per drawing.
I had also tried selecting all dimensions and changing the dim style to another type then changing it back but the rarely worked for all dimensions.
