Xiao16
en respuesta a: Xiao16
I figured out how to change the base point in the block editor. In the palette, I selected the basepoint, then enter the desired location, -20.28,17.11. Existed and saved the change. The base point changed.
Then, I changed "Decimal" in the Primary Units which is in the dimension style. Then, I got a solution which matches the solution of the question.
I hope my question and my solution could solve someone else's questions regarding how to change the base point of the block.
Thank you for everyone putting the effect on solving the question!
