1232 Vistas, 8 Respuestas
Why does my block turns into messy lines after converting into pdf?
I am really having a hard time fixing this issue. When I am in the model, the blocks are all okay but when I convert it into pdf, blocks became so messy. Please help.
See attached screenshot on the pdf
imadHabash
en respuesta a: Anonymous
can we have a part of your CAD drawing file for testing please ( attache it here ) ?
Imad Habash
en respuesta a: imadHabash
I have to delete some parts of the drawings, and I noticed that whenever I delete then plot the document, the zigzag look of the chair blocks diminishes also. It became smoother unlike the whole drawings.
So I attached the file, and if you convert this into pdf, the chairs looks so messy. It is not solid , it has open joints and very ugly looking
ennujozlagam
just tried to plot into pdf and it looks okay. try to change your ctb plot setting line thickness and see if helps. thanks
imadHabash
I have a good final result and without a problem !!! I think that you need to check and review again your Plot settings . select the right and proper paper and scale then untick plot object lineweights , any changes ?
Imad Habash
ennujozlagam
en respuesta a: ennujozlagam
mabuhay.....:cara_guiñando_un_ojo:
Sorry but this dont work on my file.
ennujozlagam
try these attached file including plot style and see if helps. thanks
ChicagoLooper
Do you run Adobe Acrobat?  If you do, change your printer in the Plot Window like this:
Chicagolooper
