imadHabash
en respuesta a: Xiao16
>> Palm Tree' block in the block editor and change its base point to -20.28,17.11 coordinates.
Click on below image and look where is -20.28,17.11 coordinates appear .
>> What is the distance between point P and the point on Palm Tree block where all leaves merge
Depending on your inputs ...
If do you want to make a basepoint while you're in block editor try to use Basepoint parameter from Block Authoring Palette .
Imad Habash
