- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am preparing for the AutoCAD certificate exam. One of the exam objectives is to recreate the boundary around a selected Hatch or Fill pattern. I am having trouble with it.
I tried to click on recreate command, then selected either Region or Polyline, then typed "Yes" or "No".
I mean I tried four combinations:
1. Region, "Yes"
2. Region, "No"
3. Polyline, "Yes"
4. Polyline, "No"
However, no matter which combination, nothing appeared later in the command line. Therefore, I didn't how should I continue to work on it. I mean I don't know how to recreate a new boundary for the Hatch.
Does anyone know how to recreate the boundary? Thanks!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HATCHEDIT command does that all day long for everyone else in AutoCAD: need to switch?
are you sure those are hatch patterns?
Are you ignoring possible error messages or alerts at the commandline that you may not see because it is only 1-line tall?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you mean that you are selecting recreate in Hatch Edit, you may be generating a PLINE without knowing it. When I do your process (through Hatch edit) I select PLINE, then Y that yes I'd like the line associated with the hatch. Then the Hatch editor pops up again, I hit enter a final time, it creates the line on whichever layer is current. I have it set to open the full hatch editor though, and I cannot remember what setting that is. Double check that you aren't creating lines or regions on a frozen or turned off layer.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you, everyone's effects!
I think I misunderstand the recreation of the boundary in the first place. I thought that I needed to make a new boundary by polyline and region to change the shape of the hatch. However, actually, a new region or polyline will be created around the hatch by used the Recreate Command.
