nrz13
en respuesta a: loredoj
If the PDF drawing is to scale (e.g. 1/8" = 1'-0"), you would bring the drawing in at a scale factor of 12 x the denominator (assuming architectural foot-inch units), so 8 x 12 = 96 scale factor.  If it were at 1/4" scale, it'd be a scale factor of 48 (4 x 12).
If the drawing is scaled to fit and not a known scale, then a known dimension (such as a door opening) is a good way to adjust the scale.  You can use the SCALE command and select the Reference option.  Draw a 3' line at the edge of the door opening (assuming a 3' door) and then scale your PDF by reference to that 3' line.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
