coolkris
333 Vistas, 4 Respuestas
Material display proportion in xref while z scale factor changed.
Dear all,
Please find attached image and drg. where in I try xref bridge levation from xref file(source)
The source file has got material attached. While xref the source file I have scaled up z scale. How to change mapping of materials of xref.
I am getting blue color on parapet face and pier face on left in the attached cad file.
Krish
coffeejeanpaul
en respuesta a: coolkris
Good day.
Cannot see clear the question.
Also the dwg we do not get the reference files with it so it would just be blank on our side.
Try to bind the file to the drawing ?
If you don't want, try to change the settings of the reference file or plotting settings to match your requirements,
But maybe add one of the reference file, to better understand.
Good luck sir
coolkris
en respuesta a: coffeejeanpaul
Thanks for the reply and sorry for not binding the file, please find attached.
vinodkl
Hi @coolkris
Sorry, the Xref files are still missing. You need to "Etransmit" the drawing so that Xref and drawing can be sent as package .zip file :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
coolkris
en respuesta a: vinodkl
Dear all,
 Please find attached transmittal, while I added distance light and mapped the material in current file, I got better results. But it is not uniform, like crash barrier etc.
Mainly I want to remove blue shade that is affecting the image.
Krish
