bterpeluk
317 Vistas, 1 Respuesta
Attribute Definition in Editable Block is Off-center in Autocad LT 2016
Most of the blocks (finish symbol, elevation key, room name & number block, etc.) that I've made and have been using for years now show up with the editable text (attribute definition) off-center. Worse, this affects not just one file, but all files that contain those blocks. When I go to edit the block, I'll select an attribute definition that is justified bottom center. When I select the bottom center grip to move it, the text jumps so that I'm now gripping the bottom left of the text. Wherever I place the text, it jumps back so that the point where I click becomes the bottom center again. Unfortunately, relocating the text this way still doesn't fix the block.
Fortunately, the blocks are fine when opened on a colleague's computer, so I believe the problem is local to my computer. Is there a fix for this?
