01-27-2021
02:27 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-27-2021
02:27 PM
>>>...Autodesk Desktop says there are no updates...<<<
That means nothing, that POS can report false info as often as not: ABOUT command will confirm if you are running the latest (2020.1.3) or not, check now.
>>>...But recently have been noticing...<<<
SO what changes with your office's setup about that same time? Your IT needs to do a deep dive to find out, I suspect it's not so much an AutoCAD setting as a resource change that is the cause. Could be as dumb as a printer changing network address, to missing folders, to a conflict with an update or software installed at the same time.
>>>...named things like "Audit_E_921837987228-0" ...<<<
Looks like someone already tried to fix your files (and found errors as you are finding in them).
HTH
HTH
