ctbailey
1027 Vistas, 7 Respuestas
Sheet Set Manager not fully opening .DST file
AutoCAD 2021 is not fully reading any DST files that I created in release 2016.
This seems to be a local problem to a few physical workstations in my office.  When I open the attached DST file on a clean machine that never had 2016, they will read the file.
_______
Craig T. Bailey, PE, LLS, PSM
Bailey Associates
www.bailey-associates.com
Etiquetas (1)
Etiquetas (1)
ctbailey
en respuesta a: ctbailey
I've decided just to start the DST "templates" again from scratch.
I suppose a minor corruption isn't totally unexpected.  So far, I've successfully created a new .DST "template" that is working.
Case closed, I suppose.
_______
Bailey Associates
JTBWorld
If you want, send me one DST, I might be able to fix it.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
reynaFWEFC
en respuesta a: JTBWorld
I can't see my DST files on my folder when I save it.
JTBWorld
en respuesta a: reynaFWEFC
After you save it can you open it again? If so, you might look in wrong folder.
In Sheet Set Properties you can see the path to the DST under "Sheet Set data file".
Jimmy Bergmark
reynaFWEFC
Thanks to replay to my problem.
I have been trying to create a new sheet set using an existing drawing but when I try to browse for the DST file from AutoCAD, no file appears in my folder is totally empty (neither where I save it nor where it is saved by default).
[A computer screen with a white square on it Description automatically generated with low confidence]
[cid:image002.png@01D9A5AF.20C23A80]
I hope you can help me solve my problem.
Thank you!
Reyna Carbajal
pendean
@reynaFWEFC Nothing attached: you have to come to the website to share content.
Also... DST save locations if you are not paying very close attention default to the last used folder: bet your new DST file is where you saved that last DST file you created. Go look for it.
You can also perform a system wide search for DSTs like this https://support.microsoft.com/en-us/windows/find-your-documents-in-windows-5c7c8cfe-c289-fae4-f5f8-6....
JTBWorld
What command do you use to open the DST? Do you see it in Windows File Explorer?
Jimmy Bergmark
