en respuesta a: Anonymous
I am attaching the DWG file, the KMZ file is not supported in the Attachment options. I would be grateful to you if you can convert it to KMZ and check that in GE ( I have used Global mapper software for Converting DWG to KMZ) and check this DWG in Autocad maps. ( Rotary is the start of the drawing and go till the last point, you will notice the shift from the midway alignment in Autocad maps,  but no such thing in GE.
Thanking you in Advance.
