BeKirra
en respuesta a: Patchy
@Patchy wrote:
Explode all the polylines , then use command OVERKILL, then use Pedit, multiple, then Join.
OP mentioned the command pedit can't be used.
@Anonymous Can you give more details?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
