BeKirra
en respuesta a: Anonymous
Command pedit is what your are looking for.
Select the option join to join all polylines into one piece.
All you have to ensure is endpoints of 2 polyline segments meets perfectly otherwise they would not be joined into one.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
