- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Join more polylines to one
Dear Community,
I would like to ask for your support. I have a .dwg and I would like to join the polilynes into one shape. I tried several methods but none of them worked. May I ask you to please support me how can I do it? Attached my file.
Thank you,
Máté
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Command pedit is what your are looking for.
Select the option join to join all polylines into one piece.
All you have to ensure is endpoints of 2 polyline segments meets perfectly otherwise they would not be joined into one.
HTH
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
or you can type in your command prompt BOUNDARY > select pick points > pick inside your objects. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
..or Join. Or LINEWORKSHRINKWRAP.
If joining (PEDIT or Join) all lines/polylines must have same elevation and have matching endpoints (exact).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Dear guys,
Thank you so much for the support. I am using Autocad 2010 but the PEDIT didn't work. Anyway thank you so much for the upload I will use that file. On the other hand, I will try the other methods whenever I will have possibility to use a newer version. Can you please let me know your method? What did you do to reach that result you uploaded?
Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There are a few lines with zero length and overlapped that's why you can't join them.
Explode all the polylines , then use command OVERKILL, then use Pedit, multiple, then Join.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Patchy wrote:Explode all the polylines , then use command OVERKILL, then use Pedit, multiple, then Join.
OP mentioned the command pedit can't be used.
@Anonymous Can you give more details?
X² + Y² = C²
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
PEDIT doesn't work if it has 2 zero length in there.
Have you even tested it out yet?
Have a look if you want:
