j.palmeL29YX
en respuesta a: Anonymous
@Anonymous wrote:
@Anonymous wrote:
  1. Click Home tab Modify panel Extend. Find.
  2. Select the objects to serve as boundary edges. Press Enter when you finish selecting the boundary edges.
  3. Select the objects to extend and press Enter a second time when you finish selecting the objects to extend.
Did you have a fix on this issue?
Which issue is your problem.
- Explode the array
- start the extend command
- select the horizontal and the vertical boundary line, Enter
- select the lines you want to extend at the side where you want extend. (you can also use a fence)
- done.
Jürgen Palme
