dbroad
en respuesta a: cgmichail
Seems an appropriate response to me.  You went from selecting objects to asking AutoCAD to select m2p.  Your middle sequence was correct.  Select objects, choose command, select displacement points.  Objects stay selected.
M2P isn't a command. It is a command option for selecting points.  By selecting M2P, you cancelled the selection because it was an error.  Read the command line when things appear to go wrong.  Don't use the default floating command line unless you switch to the textscreen after the error with F2.
Architect, Registered NC, VA, SC, & GA.
