cgmichail
1007 Vistas, 4 Respuestas
Auto Deselect using Shift
I've just encounter a problem, in which never happened before.
Selecting 2 polylines (or 1 closed) and using the shift command (shift and click), the object(s) deselect from itselves, so it's impossible to use "Shift" command. No there wasn't any problem all this time.
And I 've just noticed that in any object can happen. Aec or a simple line.
I am using Architecture 2020
The link is a 7 sec gif of the problem
Any ideas?
Thank you in advance
Harrys
https://gyazo.com/f81bfe21376bfb0b49c509050517f7b9
P.S
I was thinking if there is a hidden error, but nothing.
"Command: _AUDIT
Fix any errors detected? [Yes/No] <N>: Y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 20500 objects audited
Auditing Entities Pass 2
Pass 2 20500 objects audited
Auditing Blocks
248 Blocks audited
Auditing AcDsRecords
Total errors found 0 fixed 0
Erased 0 object"
Etiquetas (1)
  • Bugs
