- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I've just encounter a problem, in which never happened before.
Selecting 2 polylines (or 1 closed) and using the shift command (shift and click), the object(s) deselect from itselves, so it's impossible to use "Shift" command. No there wasn't any problem all this time.
And I 've just noticed that in any object can happen. Aec or a simple line.
I am using Architecture 2020
The link is a 7 sec gif of the problem
Any ideas?
Thank you in advance
Harrys
https://gyazo.com/f81bfe21376bfb0b49c509050517f7b9
P.S
I was thinking if there is a hidden error, but nothing.
"Command: _AUDIT
Fix any errors detected? [Yes/No] <N>: Y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 20500 objects audited
Auditing Entities Pass 2
Pass 2 20500 objects audited
Auditing Blocks
248 Blocks audited
Auditing AcDsRecords
Total errors found 0 fixed 0
Erased 0 object"
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Your GIF is difficult to interpret. If you are still having a problem, make a screencast that captures the key strokes. See
https://knowledge.autodesk.com/community/screencast.
It looks like you shift+right clicked though, not shift+click since you brought up a menu. Shift+click is intended to deselect. CTRL+click is intended to add to selection.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Seems an appropriate response to me. You went from selecting objects to asking AutoCAD to select m2p. Your middle sequence was correct. Select objects, choose command, select displacement points. Objects stay selected.
M2P isn't a command. It is a command option for selecting points. By selecting M2P, you cancelled the selection because it was an error. Read the command line when things appear to go wrong. Don't use the default floating command line unless you switch to the textscreen after the error with F2.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I thought in the past (6.7 years), was working also like that way. Using the m2p first (with shift), to move objects.
Thank you.
