- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I can only start AutoCAD with the "/nohardware" switch which leads me to the conclusion that the issue must be with the hardware acceleration.
As i had this issue before and tried everything that was mentioned at one of the troubleshooting pages for the "App XYZ cloeses after splash screen" i tried a clean install of windows, which funny enough solved the problem for a few days. After installing all the neccessary drivers i downloaded AutoCAD and it startet up perfectly fine and did so until today. Now i have the same old issue with AutoCAD crahsing during the splash screen with no error message. Now it only starts up when i disable hardware acceleration, which makes no sense since i did not change any hardware component nor any driver related to this.
I found another thread with a similar or the same issue and the problem was solved by using a graphics driver from 2019 which is not an option for me as i partially use my pc for gaming and some of the newer games wont run properly with drivers that are just too old. Is there more information out there what causes this issue? Is there a listing of "compatible" nvidia drivers?
My graphics card is an nvdia RTX 2070.
¡Resuelto! Ir a solución.
