ChicagoLooper
en respuesta a: JohnC_ISM
Awwww, no. You stated you were using GPS points. That tells me you’re dealing with x,y,z data collected by a work crew in the field using hand-helds. By flattening the points you have taken the technology out of your data, you removed the elevation data. The elevation is there for a reason, a design reason or an analytical reason.
Just because you can flatten doesn’t mean you should.
Chicagolooper
