ChicagoLooper
en respuesta a: JamaL9722060
Circles? Surveyors using circles? Why?
BTW, some consider Survey drawings and GIS drawings are like oil and water, they don't mix.
Get rid of the circles, they can't be used if your end goal is shapefile. To begin, use MAPCLEAN command. Next, you'll need to make the parcel lines TOUCH and touching will create intersections. Depending on your specific drawing, your settings may, or may not look like this:
To create polygons which can be exported to shapefile, do this:
  1. Create a new 'PARCEL' layer. Make the Parcel layer current. Optional: Give this layer a high visibility color.
  2. Invoke the BOUNDARY command=>Click the button labeled Pick Points=>Click the interior of each parcel=>ENTER.
  3. The the individual parcels have been generated. Turn off all layers to reveal the new parcel boundaries.
The newly created boundaries are all closed polylines which can be  exported to as a feature class in shapefile format.
Chicagolooper
