01-18-2021
11:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-18-2021
11:26 AM
If the box shape is a realistic example, and an unequally-scaled Block of the 3D Solid by itself, and orthogonally oriented, you don't need to redefine the Block with Lines and non-uniformly scale that and Explode it, or export anything, etc. You can quickly "trace over" an unequally-scaled 3D-Solid box with ENDpoint object snaps in a [very aptly-named] BOX command. However, if the box is part of a larger Block with other components that you want to remain their unequally-scaled selves after Exploding, then you would need to [temporarily?] redefine that Block so that the box in it is made of something like Lines, so that the containing Block can be Exploded.
Kent Cooper, AIA
