j.palmeL29YX
en respuesta a: JamaL9722060
I think you need some programming (LISP).
A rough idea:
- check for each line, if an endpoint is inside a circle: compare each endpoint with each centerpoint, if the distance is smaller or equal than the radius of the circles (0.75) then
- change the coordinate of this endpoint to the coordinate of the centerpoint.
But this is only a first thought. I'd suggest to ask in the customization forum if someone can help (or perhaps you can do it yourselfe).
Jürgen Palme
