- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Explode non uniformly scaled block (3DSolids)
While searching for a solution to my current problem I found in >>this<< post:
"AutoCAD will not explode non uniformly scaled blocks that contain Regions, Surfaces and/or 3dSolids."
Is this still the current behavior of AutoCAD? Or is in the meantime any possibility (or found someone a workaround) to explode a non uniformly scaled blockreference which contains 3DSolids.
Example: Given is a block definition including a 3DSolid box a x b x c. After inserting the blockreference non uniformly scaled I see a "box" a' x b' x c'. (How) can I get a 3DSolid with the dimensions a' x b' x c' ?
THX
Jürgen Palme
