438 Vistas, 6 Respuestas
Attributes
Hi All,
i have annotated attributes in model space with a scale factor of 4. My intention is to fit in a paperspace with a scale of 3"=1'-0". But when in paperspace . it looks like this. (pls see screenshots). Any reason's for these and how to solve it?
I don't have a problem though if i put these attributes in my paperspace.
Thank you
pendean
en respuesta a: Anonymous
Are you using Annotative test styles in that DWG?
Post your DWG too.
en respuesta a: pendean
Yes. i'm using annotative sir..
Please See DWG File
pendean
Your DWG has no paperspace layout created/usable to show your issue like in your earlier screenshot.
Try again? This DWG file is useless other than to confirm you've done nothing to create annotative text with the Swis721 font you seem to like to use everywhere, and the two default "annotative" styles are not even set or ready for use in paperspace.
Did you get a chance to review tutorials online or YouTube yet? you have a way to go.
Here
vinodkl
Hi @Anonymous
Instead of using annotation for the attributes, try making the block annotative and keep the scale of the block as 1 instead of 4. Now set the annotative scale in model space to 3"=1'-0" and paper space :cara_con_una_leve_sonrisa:
See attached drawing.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
