01-14-2021
07:47 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-14-2021
07:47 AM
I believe this is approximately what I did to get to this point.
In the first picture are the three separate panels I made via extructions and some surface modeling. I attached them all together using corner snaps. I then created a very thin green 3D shape and subtracted that from the three panels to union them together, and level out the bottom of the assembly since it was uneven. The reason I need to join the parts is to create new panels that fit together, which I can do by sculpting out the correct shapes from the unioned assembly.
I'm not sure why the subtract command compromises certain connections on the model.
-Ray
