leeminardi
en respuesta a: raybryant1998
If the design goal is to have 4 flat polygons that have a thickness I would explode then delete all the geometry except the 4 profiles.  Define a ucs for a specific profile and create a polyline on that profile using "c" to make sure the polyline is closed.  You can then extrude it to the desired thickness.  Repeat for the remaining profiles.
lee.minardi
