petergil
3050 Vistas, 14 Respuestas
viewport unlock/lock option not shown in shortcut window
I used to be able to right click on a viewport and an option to lock or unlock was there. The option is no longer in the shortcut window. How do I turn it on??
Kent1Cooper
en respuesta a: petergil
First left-click-select the Viewport on its boundary, then right-click.
Kent Cooper, AIA
Patchy
If the viewport is on locked layer, then it can't.
petergil
The viewport is not locked.
If I left click the viewport then right click a shortcut box comes up but no option to lock, unlock, off, etc. I used to be able to but since upgrading to 2021 this started happening. Am I missing something in "options" say under shortcut menu??
petergil
Patchy
Oops, I gave you a wrong answer.
Ask the Civil3d group and see if it happens to them with 2021 version.
Kent1Cooper
If that's a change in 2021, you can at least pick Properties... from that pop-up menu -- locking of the Viewport should be a choice in the Misc category [unless that has also changed].
Kent Cooper, AIA
petergil
I think you're right its a civil 3d shortcut menu gliche. Ill post there...
GustavoUbriaco
hi there! how about this option in the status bar?
Gustavo Ubriaco Contreras
petergil
Yes excellent that works I didnt realize they added a lock/unlock button at the bottom. ty.
The right click shortcut menu shows viewport options in autocad but not in Civil 3d. I dont know why. It must be a Civil 3d issue....
RobDraw
Not sure when it was added but it's been in AutoCAD for quite some time.
Rob
GustavoUbriaco
excellent! We are here to help us each other!
petergil
en respuesta a: GustavoUbriaco
So it looks like has happened before a glitch in the CUI. See below link to another post....
C3D 2021 - Viewport lock does not appear in the Right Click Menu anymore - Autodesk Community - Civi...
I do not dare change the CUI.
Hopefully Autodesk will read this and fix the error for the next update!
petergil
HERE IS THE SOLUTION..in CIVIL 3D forum...thanks to Jeff M
Why not? It takes less than 30 seconds...here's a short screencast of how to do so:
https://autode.sk/37Zmf3c
Draughter83
Fantastic, thank you for the link to the fix.
