Kent1Cooper
en respuesta a: waseemtarik
@waseemtarik wrote:
.... I uploaded the file without changing anything, however when i select the hatch it doesn't do anything, ....
But it shows it, and lets you select it?  Are there any messages?  What does "doesn't do anything" mean?  Does it let you select objects or pick in an area, but you don't see any result?  You could have the scale off -- it should be the same as the wall thickness, in drawing units [not in your sample drawing's metric-imperial mix with a so-called 3" thickness that's really seventy-some drawing units].  And follow the instruction about the blank line at the end of the file [one of the most common errors people make is to not do that].  If those don't fix it, post the file you made.
Kent Cooper, AIA
