- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@waseemtarik wrote:
.... yes almost same look if that is possible, to be hatch not block. ....
My image was of just drawn Lines like yours, but it's easily defined. Here's a Hatch pattern definition:
*MWInsul, Mineral Wool Insulation
0, 0,0, 0,1
90, 0,0, 0,.4, .8,-.2
90, .2,.2, 0,.4, .8,-.2
Use it at a scale factor the same as the wall thickness, at a rotation angle that is the direction the wall edges run, and with its origin at a corner of the Hatched area. It looks like this, at a rotation of 0° with the origin at lower left:
Be aware of the need to match the scale factor to the wall thickness, and use it only in parallel-edged areas, otherwise it looks like these:
You can change the pattern name to whatever you want. Save it to a file with a .pat filetype ending, somewhere that AutoCAD knows where to look for it, with the file name exactly matching the pattern name [minus the * at the beginning], and be sure the file ends with an empty line, not at end of the code content. [If you keep the pattern name as I have it, the file must be called MWInsul.pat, though that is not case-sensitive.]
