R_Tweed
en respuesta a: waseemtarik
I use the batting linetype for basic sections, changing the linetype scale through the properties palette will adjust the width of the pattern. Based on your dwg you could make a block like the one attached that will fill width and length.  You might want to check the dynamic block forum to see if someone has posted something similar. If you are a subscriber and have access to ACA there is a detail component for batt insulation that allows tapers as well.
