Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
3.375 would round down to 3.38
3.50 would display as 3.5
3.00 would display as 3.0
Is there a combination of commands which would enable that? Thanks.
I don't think there is.  The first two can be achieved by a precision of 2 decimal places and with trailing zeros suppressed, but suppressing trailing zeros means all of them, so the third item wouldn't be possible.  That would require a precision of 1 decimal place, without suppressing trailing zeros, which will make the first item impossible.
It might be possible to write a routine that would look at the measured distances of selected Dimensions, check their decimal content, and with certain results impose DIMDEC and DIMZIN values with DIMOVERRIDE.  But that would mean the Dimensions with those overrides wouldn't change appropriately if the dimensioned things were Stretched in certain ways -- you would need to run the routine on affected Dimensions again.
Kent Cooper, AIA
