- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Chamfer will do that, though it's a little less intuitive than in 2D work.
Command: CHAMFER
(TRIM mode) Current chamfer Dist1 = 2, Dist2 = 2
Select first line or [Undo/Polyline/Distance/Angle/Trim/mEthod/Multiple]: {select on edge somewhere}
Base surface selection...
Enter surface selection option [Next/OK (current)] <OK>: N {if not highlighting the larger flat surface}
Enter surface selection option [Next/OK (current)] <OK>: {Enter when showing correct surface}
Specify base surface chamfer distance or [Expression] <2>: {give distance if default is not as desired}
Specify other surface chamfer distance or [Expression] <2>:
Select an edge or [Loop]: L
Select edge of loop or [Edge]: {select edge -- it should highlight looping around}
Select edge of loop or [Edge]: {Enter to complete}
You can call for the Angle option and give it 45°, but it seems to come back and ask for confirmation on the distances anyway.
