1461 Vistas, 8 Respuestas
3d chamfer with angel
How to chamfer this in 3d?
2 x <45
Kent1Cooper
en respuesta a: Anonymous
Chamfer will do that, though it's a little less intuitive than in 2D work.
Command: CHAMFER
(TRIM mode) Current chamfer Dist1 = 2, Dist2 = 2
Select first line or [Undo/Polyline/Distance/Angle/Trim/mEthod/Multiple]: {select on edge somewhere}
Base surface selection...
Enter surface selection option [Next/OK (current)] <OK>: N {if not highlighting the larger flat surface}
Enter surface selection option [Next/OK (current)] <OK>: {Enter when showing correct surface}
Specify base surface chamfer distance or [Expression] <2>: {give distance if default is not as desired}
Specify other surface chamfer distance or [Expression] <2>:
Select an edge or [Loop]: L
Select edge of loop or [Edge]: {select edge -- it should highlight looping around}
Select edge of loop or [Edge]: {Enter to complete}
You can call for the Angle option and give it 45°, but it seems to come back and ask for confirmation on the distances anyway.
Kent Cooper, AIA
en respuesta a: Kent1Cooper
Yes. That can also do chamfer edge command.
But can i somehow insert distanc and angel?
Patchy
Follow the prompt,
Chamfer, then A............,then .......
en respuesta a: Patchy
CHAMFER is for 2d
CHAMFEREDGE is for 3d.
I can not do that.
Patchy
Use expression
Tan(??)*2
Can you explain that ?
I have just one lenght. How tangens can help. :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
Kent1Cooper
I gave it distances.  I tried the Angle [it's the season for angels, but they're not relevant here] option, with a distance, but it came back later and asked for the two distances [or for confirmation of them], so since it was equal distances, I just used those, and not the angle.  But you can -- just pay attention to the prompts, and read about the command in Help if the prompts don't make sense.
Kent Cooper, AIA
Patchy
Example:
