en respuesta a: Anonymous
Most of the time, either in Model or Paper Space, my AutoCAD 2014 shows and regenerates the drawing order properly.
But sometimes, after the REGEN command, random lines and hatches are displayed in the wrong order (not all of them, and it ALWAYS shows correct in plot). If I keep drawing or switch back and forth between Model and Paper Space, the REGEN would eventually display the correct draw order.
Sometimes, inside a viewport, using REGEN shows the wrong draw order for some elements, and out of the viewport, repeating REGEN command fixes it.
It does not seems to be a problem with drawing order, since it just randomly start showing the wrong drawing order after a REGEN, and my plots are always correct despite that.
I even start to believe that it may be a hardware problem, since I already formated the PC multiple times, and tried multiple versions or AutoCAD (2012, 2013 and 2014).
