- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Leaders show all previous actions when highlighted.
I am new to AutoCad, so I am not sure how to explain this problem. It did not do this before, so I do not know what changed on my drawing. Any time I select a leader it shows all the previous actions I did. For example, any deleted extra leaders, or previous movements. It can get pretty confusing.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You are seeing the annotation scales applied to that mleader. You can turn off the display with SELECTIONANNODISPLAY set to 0. Or you can go into properties for that mleader and delete the other annoscales if not needed.
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think you mean that you see Multi scale shapes for the same selected leader . if that what you see then you have to know that you're treat with an annotative leader. you can by SELECTIONANNODISPLAY (System Variable) = 0 stop showing those temporarily dimmed multi scale . if you have another case please attache here an image that describe well your issue .
Imad Habash
