RONNIEJ
690 Vistas, 6 Respuestas
Circles not round in paper space
Good Afternoon,
I am wondering how I get circles that have been pushed/pulled to print round. Sorry if I am not explaining this correctly. I made two circles and used the push/pull to create a piece of pipe. In model space it is round but not in paper space or when it is printed.
pendean
en respuesta a: RONNIEJ
Post your DWG file please.
RONNIEJ
file attached
imadHabash
Pick inside your VP then type VIEWRES command and change the value for 20000  . also you may try from GRAPHICSCONFIG command to check that your hardware acceleration is turned ON and High quality geometry is selected . also you may need to update your graphic card driver .
Imad Habash
RONNIEJ
en respuesta a: imadHabash
Thanks for the input. I tried this and updates to any drivers. No improvement.
devitg
@RONNIEJ   it is not your circle , it is  your 3d solid that show SQUARED.
j.palmeL29YX
Something seems to be wrong with your viewport.
After creating a >>new viewport<< (video)  you get a smoothed contour.
[EDIT:] Edit/change the VIEWRES variable as shown in the video is not necessary
HTH
Jürgen Palme
