Kent1Cooper
en respuesta a: Kent1Cooper
@Kent1Cooper wrote:
For the decimal-places issue, I think you don't want the Roundoff setting, but the Precision setting [the DIMDEC System Variable].  ....
Actually, you can do it with the Roundoff setting, but set the Roundoff to 0.01, i.e. round off to the nearest multiple of that [a value of zero means don't round off at all, but use the Units precision setting].  The four decimal places displayed in the Roundoff slot in Properties are a function of that same Units linear-measure precision setting, not of the Dimension settings.
The DIMZIN setting controls whether trailing zeros are displayed, if you'd rather round to the nearest 0.01 multiple and suppress trailing zeroes [rather than using the DIMDEC setting to limit it to two decimal places].  If you do it that way, a value that rounds to [for example] 3.20 will display shortened as 3.2.
Kent Cooper, AIA
