- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
.... there are some very odd blocks that I can’t edit. I get the message “Cannot REFEDIT anonymous block” – all I want to do is change the color from yellow to black to make it easier to see them on a white background.
That *X beginning to the Block names for the yellow arrows is from the days [long ago] when a Hatch Pattern was a variety of "Block" with an anonymous name like that. That's why, if you Osnap to their insertion points, they're all in the same place [the SNAPBASE origin in the original drawing from which the patterns were generated at the time they were made], and why the closely-spaced lines that make them up all run in the same direction, regardless of the direction the arrow points, and why every one has its own distinct name [different numbers after the *X]. I think you may be out of luck, and may need to just bite the bullet and Explode them all. The pieces have yellow as a color override, but they're on the same blue Layer as the turn-the-corner Lines that connect to them, so you could set their color to ByLayer and they should be very visible, if not black.
