- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
You are the second one i read about that issue.
Your Video is good, but not perfect (the commandline is not visible fully, the video started a bit to late..)
next time it would be welcome to see a AutoDESK Screencast with recors command and timeline.
For AdeskProducts really the best way: https://knowledge.autodesk.com/de/community/screencast
I guess you work normally, but it won't help you if I say "99% don't have the problem".
So how can we get to the bottom of this?
Please provide an example DWG, preferably the one from the video.
And your current settings too!
After you've created and saved the sample file,
start command: SYSVDLG, [SaveAll ..]
If the command is unknown to you, go this way:
Command: LOGFILEON
Command: SETVAR? *
then take the logfile from: LOGFILEPATH
(the name and the logfile you can read from LOGFILENAME)
Share your DWG and *.svf (or *.log) files with us. ZIP -> Attach
The video was (and is?) available for me, attached as zip again
Sebastian
