455 Vistas, 2 Respuestas
12-09-2020
03:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-09-2020
03:04 AM
Is there a formatting option that will allow a field to return a value from an object as a rounded up number? For example. If I take the line length of a polyline as a field and the value returned is 892.2464mm is there any way to remove the trailing values (i.e to display 892mm with no decimal values following)
Example attached to the problem.
¡Resuelto! Ir a solución.
