454 Vistas, 2 Respuestas
Removing trailing numbers from object field values
Is there a formatting option that will allow a field to return a value from an object as a rounded up number? For example. If I take the line length of a polyline as a field and the value returned is 892.2464mm is there any way to remove the trailing values (i.e to display 892mm with no decimal values following)
Example attached to the problem.
Etiquetas (3)
Etiquetas (1)
  • FIELD
imadHabash
en respuesta a: Anonymous
it can be done when you right click your digit then Edit Field . follow below image to get what you need .
Imad Habash
Thanks!
