baykakabay
1174 Vistas, 12 Respuestas
The TRIM command has the cut line beyond the frame
Video The trim command works incorrect when I want to trim multiple lines. But when I trim 1 object, it trims correct. UCS is not too far (can see in video)
Etiquetas (1)
Patchy
en respuesta a: baykakabay
Attach your .dwg
baykakabay
en respuesta a: Patchy
I delete that file. But this file has problem with trim too
Patchy
Because it's millions miles away from 0,0,0.
baykakabay
I relocated my usc closer, but the problem still remained
Patchy
It works for me.
You don't move the UCS, look at the locations of your lines.
use Move, select everything and click on one of the line, type in 0,0,0
It will work.
pendean
Your video is too fuzzy, not very clean: try a better recording option, like this freebie https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
It looks like you are not able to complete a selection with FENCE perhaps? Who knows.
pendean
I can't repeat the problem in your posted file.
pendean
@Patchy means this (see attached)
Patchy
en respuesta a: pendean
This is what happened
Select all lines to trim and when selected it skipped and not using the nearest line as a cutting edge.
Kent1Cooper
How far away?  If the drawing unit is a millimeter, approximately 9 times the distance from the Sun to the Earth.  That kind of distance can cause many problems, because AutoCAD can work with only 16 significant figures.  I would look into your drawing template files, to see whether they are the source of things being so far away from the origin.
Kent Cooper, AIA
Patchy
en respuesta a: Kent1Cooper
Mars coordinates?
Kent1Cooper
@Patchy wrote:
Mars coordinates?
More like Saturn coordinates.  It's about 9-1/2 times as far from the Sun as we are, so only slightly beyond those locations in the drawing.  Mars is much too neighborly -- a mere [roughly] 1-1/2 times as far.
Kent Cooper, AIA
